вот пошаговая инструкция на примере неровской или роксиовской проги
Step
Launch your DVD authoring software, such as Nero Vision or Roxio Creator. When the program loads, begin a new project using the "Make DVD" option. Depending on the software, you may have the choice between "DVD Video," "DVD Data" and "Editable DVD"; choose the "DVD Video" option.
Step
2
Select the "Add Video Files" option when the DVD authoring software asks you to choose a video source for the DVD. A menu will open up so that you can choose a file; browse to the location of the MP4 file that you wish to burn onto your disc. Choose the file that you want and click the "OK" button. Should you wish to add multiple files to the DVD, either repeat the process for each one or hold down the "Ctrl" button while you select each file. When you are finished, click the "Next" button (or whichever button your software features that will take you to the next step).
Step
3
Build your DVD menu on the menu screen of your DVD software. You should have the option to create multiple menu layers, adding unique backgrounds and text as you wish. Design the menu in the way that you want it to appear on the TV screen when you watch the DVD. Once you are finished, click the button that will take you to the preview screen.
Step
4
Check to make sure that your menu look the way that you want it to. Once you are satisfied with it, make sure that you have a DVD in your DVD burner and click the button to start the burning process. When the burn is complete, the DVD will automatically eject and you will be able to watch the
