кнопки на руле
Это вход в режим самодиагностики
WITHOUT CONSULT-II
1. Go to operation check after asking the customer for symptom information. Refer to ACS-17, "ACTION
TEST" .
2. Stop the vehicle to start the self-diagnosis.
3. Turn ignition switch OFF.
4. Turn ignition switch ON, and within 5 to 10 seconds, press
ACCEL/RES switch 5 times. Then press COAST/SET switch 5
times to start self-diagnosis.
это сброс ошибки
Self-Diagnostic Erasing Method
1. Stop the vehicle and turn the ignition switch OFF.
2. Turn ignition switch ON and start self-diagnosis.
3. During self-diagnosis mode, press CANCEL switch 5 times, and DISTANCE switch 5 times in this order.
CAUTION:
Press them within 10 seconds after pressing CANCEL switch at first.
When operation is not completed within 10 seconds, start again from above go to 2.
